Sizing maindistribution line and transmisionline pipe 2
marBz
38
Im designing a domestic water system for a 1400 population, i want to know how to obtain the size of the maindistribution line, trasmission line, and pipe used inside the house??
I want to obtain this sizes economically.. we have a limited budget...tnx a lot.
Here is the information that you are looking for.
For a normal single family residence, I recommend a 3/4-Inch water supply. If you have a very wealthy residence with multiple bathrooms, etc. you should upsize to at least to 1-Inch service.
Water mains will probably be 50 mm with 150 mm transmission mains.
See the following document:
suwerte
one more thing the AWWA is refering for a 1500mm main distribution. is inner, nominal , or outer diameter?
Pipe diameter usually refers to the nominal inside diameter.
