What is the most practical variable to considered when sizing the back pressure valve for the metering pump ?
In most of the cases, the pump process discharge flow is having a bigger size such as 2" port diameter
Given rated flowrates of the pump would allow me to determine max pulsating flow of the back pressure valvr stated in some manufacturer such as Grifco or plasomatic valve.
If based on this parameter the valve selected smaller such as
1. 1" back pressure valve for 2" process discharge pipe.
2.2" back pressure valve for 3" process discharge pipe.
And some I discovered the manufacturer do not manufacture the size matched to the pipe, howver the pulsating flow is sufficient.
Another question, most the curves pulsating flow vs Pressure are based on water,is it important to consider other correction factors such as viscosity and sg to get the correction factors. I have not seen there is such correction factors involved.
Appreciates your advise
