slmechanis
Industrial
So, just an exercise really, but something ive been mulling over.
Lets stick with round numbers, I have a pneumatic cylinder which needs to move a 10 lb load at the cylinder, and 4" stroke is required, the system has a flow rate of 40cv, and 200psi so there's your supply.
Now the question is: how do you size the cylinder to actuate as quickly as possible with those limitations? Logic dictates you want the smallest cylinder possible to make the most of your flow rate which dictates speed, but there must be a way to mathematically figure out how much a load would slow down a cylinder and discover where more force isn't giving you more acceleration, its just slowing you down because of the limited flow.
