I have never had to size these valves before, but I would really appreciate any input.
I understand that many manufactures have sizing programs that maks it easier and faster to size their own valves. But I want to be able to size them from first principles or equations, charts, etc. because there are some supplier that do not have such programs or softwares for sizing.
So; if I have P1, P2, dP, Q, S.G (specific gravity), what are the steps.
1. I know that I can select a valve and look up it's Cv in the manual and plug into the equation Cv=Q*sqrt(S.G/dP). is there a way to verify that one of the variables needs to be increased or reduced to ensure that the valve size for which I picked Cv is appropriate, e.g. critical velocity, erosional velocity, etc. Just a way to know that I can plug in and solve for dP, Q, or Cv and know that I will be fine.
Or can I solve for Cv from the equation above and compare it to the manufactures Cv for a given valve and know at what range/ratioo to stay...any rule or thumb? or other equations? or variables?
Thank you.
As much as possible, do it right the first time...
Thank you.
