Michael M Wilko
- Oct 12, 2016
- 15
Hi, I was hoping someone could help me calculate the size of a drive to run the following,
1. a pinch roller pulling a wire total force 50n, roller radius is 28.559, 100 rpm
2. a lobe (cam roller bearing) swung off a shaft pushing a piston arrangement down, needing 100kg of force perpendicular to the shaft, shaft being 80mm diameter - with the lobe protruding 2.5 mm (42.5mm radius), the piston has a roller contact the lobe. the shaft is turning at 1200 rpm.
3. a cam spinning at 1200 rpm - throwing a pendulum anti & clockwise 2.5 degrees, ark length only 7.5mm - so 1200 is really 600 cycle clockwise and 600 cycles anticlockwise. the pendulums mass is about 8kgs, with a 120mm moment arm, some weight is around the bearing housing and some situate around the cam mouth which is on the same swing radius of approx 100 mm. the cam is set into a birds mouth arrangement.
I calculated that I would require 4 to 5 kilowatts approximately. i would use double sided timing belts to drive all axis from one motor with a servo drive
your help would stop many sleepless hours. if you can make sense of my question.
many thank s Michael
