it depends. basically, if the soil touches the structure (or is reasonably close), you should use the original/higher ground surface if no additional dynamic analysis is performed. essentially, the soil at the ground surface is going to move like the rest of the ground surface while the deeper conditions will move less. therefore, your structure must be designed for the various accelerations and displacements. if you have tall basement walls, then i highly recommend performing additional analysis so that the wall design can account for the added seismic loads. being 25m in the ground, you should have varying values with depth therefore i'd perform a more sophisticated analysis. if you have a well-qualified engineer perform the analysis, they can help you optimize the analysis/design. there are many exploratory and analysis options available but finding an engineer that actually understands and can provide those services is the tricky part.
