woodman1967
I am working on a project where there will be Air intake hood will be installed on the flat roof of an existing building. Everything was set and ready for installation when it was discovered the roof was built using 4" siporex roofing panels. The building is 40 years old. There was a concern that the panels may be brittle and may crumble around a hole cut in the panels to allow for the intake hood.
Problem is I am unfamiliar with the product. Does anyone have experience with this? The roof joists are spaced 10' oc and the opening will be 9' square.
Any help would be appreciated
