bookowski
- Aug 29, 2010
- 983
Using 13th edition AISC. I'm looking at single angle compression members concentrically loaded.
The text for table 4-11 (allowable axial loads for concentric loading) describes that eccentricity can be ignored provided that the provision of E5 are met. So I assumed that this table is developed based on E5. However, it seems that table 4-11 is developed using E3 (compression for flex/buckling) based on KL/rz. If you use E5, Single Angle Compression Members, they refer you to use E3 but with a modified KL/r which is KL/r = 72 + 0.75L/rx (assuming case i here for simplicity). This formula puts a lower bound of 72 on KL/r so as you go to shorter lengths the results start to seriously diverge from table 4-11 (based on KL/rz).
My assumption is that E5 is intended for cases that are eccentric, but allows you to not calculate the eccentricity/moment by adjusting the KL/r. So if you have a truly concentric load (end plate connection) you don't use E5 but rather table 4-11 (or hand calc based on kl/rz). If that is the case though why do they bother mentioning satisfying E5 in the table text? Am I missing something?
