Simulation Software for simple optics
tralala
DE
Hi There!
I'm looking for a software to make simple optic simulations.
I have a plexiglass sheet and would like to simulate the output angle of a light beam depending of the geometry and input angle.
Do you know some software with which I could do this?
If there's a Shareware or Freeware, it'd be really nice.
Cheers!
Trala
Probably easy enough to set up a spread sheet in Excel so that you have some confidence the formula's are correct. freeware is always somewhat suspect until double checked. A quickie search turned up these although my security settings have them come up blank on my PC.
Perhaps a reference for a spread sheet:
Calculators (use at your own risk):
Harold
SW2009 SP2.0 OPW2009 SP0 Win XP Pro 2002 SP3
Dell 690, Xeon 5160 @3.00GHz, 3.25GB RAM
nVidia Quadro FX4600
So Trala, did you run your simulation through the software?
If so, perhaps you found the best software for predicting where light will exit a flat plane of plexiglass is a straight edge?
Harold
