W
willidavid78
Guest
Hello guys,
I have an issue with simulation.
The problem is:
- I need to put TWO rotule (ball joint) One on the TOP and one on the bottom of a AIR cylinder.
I dont know how to make connections and/or fixtures and/or contact sets in solidworks to recreate the movement of TWO ball joints.
I did it on the top using a remote load mass (displacement rigid) in one point, blocking the translations and leaving free the rotation.
But at the bottom the cylinder has a bushing that is placed in a PIN and I dont know what kind of connection I have to put between the cylinder and the pin to recreate a ball joint.
Thanks for the support guys.
Willi.View attachment 1987
There is one picture of the system.
The problem is:
