R
Raza
Guest
I am trying to run a simulation of a planetary gear system consist of four planetary gears, one sun gear & a ring gear in ProE Wild Fire. I m able to rotate sun gear on its axis & the planet gears on their axis as well as revolving around the sun gear after assigning pin & the planar connections. Sun gear & the planet gears are meshing properly. Now the problem is that what connection I should use for the Ring gear so that later on I can define gear pairs between the ring & the four planet gears. The ring gear has to be stationary & has to meshed with planet gears properly.
If I bring the ring gear in the assembly without making any connection I can make it stationary but I am unable to define any gear pairs between planet gaers & the ring gear which results in incorrect meshing of the planet s & the ring gear.
Can any body help me in this problem? I have been trying this for a long time & still couldnt finish it.
I musing mechanism options in Wild Fire.
Raza
Raza
