Z
zmarcoz
Guest
Dear all,
I have a bar which is fixed at one end. I use PATTERN to make many holes on the bar because I want to reduce weight. When I need to set the variable, I select the radius in the original hole "d20" . My question is that whether ProE will optizmate the weight by charging the size of all holes? Or it will just change 1 hole?
Image file and part file are attached 2011-11-10_222913_Files.zip
