Hey guys,
I have what I think is a simple heat transfer problem. Basically, I have a 4" schedule 40 carbon steel pipe with a 3"x3"x1/4" carbon steel angle iron welded to the top.
- The pipe has 58 psi steam @ 290 degrees F (4 bar @ 144 degrees C)
- It is in an enclosure with 700 CFM of air flow
- Ambient temperature inside the enclosure is 122 degrees F (50 degrees C)
- This is at atmospheric pressure
I am interested in knowing the temperature profile of the system at equilibrium and the time to reach equilibrium.
Please see attached rough sketch. Let me know if anything is missing.
I know this would be simple to model on an Autodesk like program, unfortunately I don't have access to the program I need.
Thanks in advance.
Thanks in advance.
