haythamsadeq
- Jan 29, 2009
- 4
Simple and Rigid beam-column connection
I have an enquiry about the simple and rigid beam-column connection in concrete structures.
The enquiry is divided into 5 questions:
First, can I assume in a multi story building braced with shear wall that the columns are pinned ended and the connection between the column and the beam is simple? And design the column as concentric column with axial load only & minimum eccentricity?
Second, if yes, Is the rebar detailing will affect the type of connection that I am assuming. That means if I have simple connection, no intersections and overlapping between beam steel and columns steel will be required to have simple connection?
Third, if I want to have rigid connection, should I detail the steel and the beam and overlap them in a special way to make sure the moment will be transferred from the beam to the column and thus I can design the column as uni-axial column?
Fourth, If I choose to make simple connection between the beam and columns, can I simply release the column in the ETABS and providing that all lateral force will be resisted by shear wall element?
Fifth, Dose continuity in concrete only provides sufficient moment transfer between the concrete beam and column with adding and steel overlapping??
It’s a very important topic and I want to discuss it with you.
Haytham Sadeq,
Fresh Structural Engineer
Haytham Sadeq,
