I have a urethane/polyester/nylon fabric laminate which we sonic weld at the seams, which forms a channel about 5/16" wide and 1/8" thick. Material is elastic and will be in water now and then also in sunlight. Storage temperature of fabric could reach 125 F at times. I need a UV resistant, low modulus, high elasticity, soft, low VOC, low skin irritation sealant to fill that channel...maybe a base cure urethane? or? Any off the shelf products you might suggest?
