lonsgsp
- May 31, 2005
- 37
Is it permissable to use a mix of 2 and 3 place decimal dimensions units (inch)in the same callout example 3 place decimal for thru hole tolerance and 2 place decimal for c'bore diameter and 2 place decimal for c'bore depth. ASME Y14.5 2009 states that in using bilateral tolerances all units must have the same number of significant digits. It does not mention anything about using the same amount of digits for use in counterbores and countersinks.
