Significant digits on round numbers
  • Thread starter Thread starter simonsp
  • Start date Start date
S
simonsp
Guest
Are there any way to set a default setting for drawings, so round numbers comes with two significant digits? -Both for the dimension value and tolerances.
E.g. 26±2 is default shown as 26.00±2.00.
I am aware that the digits is not needed, but I would like it for consistency.
Also, I do have my settings such that fractions are shown with two significant digits.
e.g. 34.54±0.05 is shown as just written.
There is a setting for this included with the drafting standards. I'm not sure what it's called, but it either includes trailing zeros (a US method), or it drops trailing zeros (European method).
An easy way to change the setting is to choose a different Standard; File + Page Setup, and choose ANSI for trailing zeros (26.00±2.00) or choose ISO for no trailing zeros (26±2).
The number of decimal places is changed with the Precision (round-off) parameter in the top drafting window.
Thank you very much, Mr.Catia!
It solved my problem :)
To clarify for anybody els; You open Catia in Admin mode, go to Tools -> Standards... -> Choose "drafting" in "Category" -> Select your standard -> Styles ->Length/Distance Dimension -> Default -> Value Display Format-> Main Value -> Name -> write "ANS.DIMM".
This, of course, has to be made for all types of tolerances that one use.
