hi... got a question guys... i am working on a 16-bit ADC IC to convert analog signals of low amplitude and frequency. I am goin to use the dual-slope architecture. After some calculations, i discovered that the frequency of the clock needed is too high (MHZ)...So the idea is working on 8 bits at a time using the same architecture to reduce the clock frequency. Is this possible and how do you combine the 2 8 -bit data to get the 16 bits again?
