Wow, there seems to be some confusion here in the use of SIF's. I notice that there are several threads active here on the "first page" that in one way or another ionvolve SIF,s.
When you find that SIF's are involved the best thing to do is do enough reading to increwase your "comfort level".
Now, haveing said that, I am afraid that I am about to reinforce the rumor on this board that I cannot say anything in just a few words. Sorry about that, please bear with me.
SIF is “shorthand” for Stress Intensification Factor. SIF’s were developed by the B31 Code Committee in the late 1940’s and early 1950’s. The purpose of the SIF is to allow some additional design margin for the fact that some manufactured and some fabricated piping components have shorter fatigue life (as measured in terms of loading cycles) than straight runs of pipe. The B31 “Committee on Flexibility” undertook a program of testing various piping components by repeatedly subjecting them to cyclic displacements thereby inducing alternating bending stresses in the components. From this testing, the Code SIF’s were developed and theses SIF’s can be found (for various pipe components) in appendices “D” of B31.1 and B31.3.
It must be remembered that the analysis methodology prescribed by the B31 Pressure Piping Codes is based upon beam theory. Using this methodology, bending stresses are simply the bending moment divided by the pipe section modulus. However, fatigue testing shows that, for a given moment, in some component configurations the stresses that actually occur are greater than would be predicted by classic beam calculations on straight lengths of pipe. Code SIF's are simply "Band-Aids" on beam theory to help connect the stresses calculated for piping components by beam theory with the real world. A B31 SIF simply reflects the test results which compared the number of cycles-to-failure of a straight piece of pipe with a girth butt weld in it, to the number of cycles-to-failure of a piping component (like the branch connection). You will note from a perusal of Appendices “D”, that the B31 Pressure Piping Codes provide SIF's that are appropriate for specific types of piping geometries (e.g., fabricated components, fittings, etc.); those which testing derived data is available. However, the B31 Codes also tell the piping engineer that if he/she has more appropriate SIF's for specific fittings they are to have the latitude to use these data. . It would be prudent for the piping engineer to peruse B31.1 and/or B31.3, Appendix "D" to determine the details of the specific component geometries for which SIF's are provided. For example, the piping engineer may specify that B16.9 Welding Tees (fittings) be used, but the "crotch radii" and general wall thickness of these fittings varies greatly from manufacturer to manufacturer. If the piping engineer determines that the component to be used in the design is significantly different from those described in Appendices "D", it may be appropriate to develop alternate SIF data.
So summarizing, the “equivalent bending stresses” that are calculated using B31, Appendix D SIF's came from (very limited) cyclic load testing of piping components and really were intended to address fatigue. These beam theory bending stresses are (for a beam that is a straight pipe) simply the bending moment about a given axis (in-plane) divided by the gross section modulus. For other piping components (e.g., the branch connections at issue here), the bending stress is calculated as the INTENSIFIED bending moment divided by the gross section modulus. This B31 calculation actually yields about 1/2 the true elastic bending stress (this is the result of assigning the girth butt weld test specimen a 1.0 SIF; for example, just for interest compare the SIF's from B31 to the stress intensifiers used in Section III of the ASME B&PV Code,(ND-3600) beam stress calculations), but these B31 calculated stresses are to be compared to the allowable stress that is also provided by the B31 Code and when used in this context will result in a reasonably conservative design for most applications.
You will note from a perusal of Appendices “D”, that the B31 Pressure Piping Codes provide SIF's that are appropriate for specific types of piping geometries (e.g., fabricated components, fittings, etc.); those which testing derived data is available. However, the B31 Codes also tell the piping engineer that IF he/she has more appropriate SIF's for specific fittings they are to have the latitude to use these data. Good stress analysis software provides the piping engineer with the capability to override the Code prescribed SIF's (that are written into the software) by specifying alternate data. It would be prudent for the piping engineer to peruse B31.1 and/or B31.3, Appendix "D" to determine the details of the specific component geometries for which SIF's are provided. For example, the piping engineer may specify that B16.9 Welding Tees (fittings) be used, but the "crotch radii" and general wall thickness of these fittings, although they DO comply with the Standard, vary greatly from manufacturer to manufacturer. When the B31 “Committee on Flexibility” performed the original fatigue tests, they used only ONE manufacturer’s fittings. If the piping engineer determines that the component to be used in the design is significantly different from those described in Appendices "D", it may be appropriate to develop alternate SIF data. If you are a piping designer/analyst and you have not read all the footnotes associated with Appendices “D”, perhaps you should take the time and read them again.
There is information available in the literature (and in some of the Codes) regarding the development if SIF's. The Welding Research Council has published the following:
Developing Stress Intensification Factors: (1) Standardized Method for Developing Stress Intensification Factors for Piping Components, by E.C. Rodabaugh and (2) Effects of Weld Metal Profile on the Fatigue Life of Integrally Reinforced Weld-on Fittings, by G.E. Woods and E.C. Rodabaugh, June 1994 (26 pp) (ISBN #1-58145-391-4) ? $64.00
To obtain this document, go here:
Regards, John.
