Hello everyone,
I'm trying to automate a process in Siemens NX using Matlab (1 of multiple steps).
I created a journal that works perfectly if I play it manually in NX. I was trying to run this journal using matlab somehow. My first thought was executing run_journal throught the command prompt to execute my journal but I can't make it. I suspect that it is related to not loading the .prt file (file of an example journal is attached).
The goal is to just edit some expressions and then export a step file.
Does anyone know how to solve this or a different way to approach this problem?
Thank you,
carreira
Thank you,
carreira
