Side View Dimensioning of Interupted Feature of Size/Chamfers/etc
njm789
Automotive
Hi all,
What is the correct way of dimensioning a feature of size that is interrupted such as the height of the part below or chamfers/radii from a side view that are continuous. Eg. Would it be 4X CHAMFER or 8X CHAMFER (is it confusing/wrong to put 8X if only 4X are visible in view)/similarly would the height be DIM, 2X DIM, or 4X DIM?
They are considered separate features so yes, 8X. Also, the 102.5 dimension should be 4X.
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
