I'm working on a project where I have a Sensirion SHT71 device tied to a PIC micro.
I'm quite sure the code is working, thats not the issue at hand. If it wasn't then I wouldnt be getting semi valid, or sometimes valid data. Also, the device sends an ACK like I2C when it gets a valid command, and I get that...and I get return data.
What is the problem is getting accurate data. I'm looking for others that have used this part successfully, to find out if there are other things I am not doing right. Can you query it constantly? Or is there settle times? Just need to get some insight.
