B
bac478
Guest
From time to time we put MIN or MAX dimensions on drawings, for example an included angle where the radius cannot exceed a certain value but can be as small as the fabricator would like. Sometimes it would be beneficial to have the model show the feature (or part in the case of an assembly) at a dimensional value other than it's min or max. I know this can be done by tricking Pro/E using the edit>setup>dim bound menu. Is there an easy way to simply display only the upper OR lower limit of a shown dimension but not both at the same time? I know I could create a relation and parameter and use the tp and tm values, but I wonder if there is a straightforward solution that I am just not aware of. Does anything like this exist? How do others show their MIN and MAX dimensions on drawings?
