ptm0270
- Oct 5, 2010
- 3
I have a question on how to extract membrane only stresses. Please correct me if any statements I make are incorrect. I'm using I-DEAS NX5 and occasionally NASTRAN from an I-DEAS .dat export. The element I'm using is a thin-shell to represent typically angles and plates less than 1". In I-DEAS, when I post-process Von Mises stress, I get "top" and "bottom" surface stresses. It is my understanding that this is considered "Membrane+Bending" stress. I want to also view "Membrane only" stress, which I believe is the stress at the neutral axis of the section. It is my understanding that the "middle" surface in I-DEAS is just (top+bottom)/2 or the average, but this is not what I'm trying to extract.
To sum things up, in I-DEAS how would you extract "Membrane only" stresses using Von Mises stress display for a thin shell element.
