May 5, 2015 #1 T Tesla77 Guest How do you show a tolerance zone on a drawing? As in a GD&T profile tolerance.
May 7, 2015 Thread starter #2 P per2fh Guest Assuming you got to the geometric tolerance box.... under the symbol tab, select unilateral when you go to place the symbol, it will ask which side you desire the tolerance to apply. select ok.
