kevingeneer
- Feb 5, 2014
- 7
I am trying to redesign a bolted joint to make it faster to install. Currently we use a properly sized bolt that has a thread engagement of around 1.5 diameters but it is desired to make it faster to install this bolt.
I am thinking what if you use an over sized bolt so you could minimize the thread engagement. Doing this gives you a big tensile stress area and a small shear stress area which is bad practice, because the threads will fail before the bolt. But if you use a big enough bolt, you could have a huge shear stress safety factor to ensure the joint will not fail at all. The length of the wrench used for installation known, so I will assume some super human hand force to size the bolt. If the bolt was big enough could you get away with just one thread holding it together?
This seems wrong to do but it could work in this situation. Is there anything that I am not thinking about that makes this a bad idea?
Thank you!
Kevin
Thank you!
Kevin
