The way in which we determine the depth of a shoring member (e.g., drilled concrete caisson) is to apply all load above fixity (e.g., shear, moment, etc.) and then use the passive pressure resistance provided in a soils report to determine the depth below fixity (an aside: right now we are using a method by E. Czerniak). Typically, we receive information such as "use a passive pressure of 400 psf/ft up to a maximum of 5000 psf". However, I recently talked with another structural engineer who mentioned that when he does his shoring design he DOES NOT use a maximum value. That is, he lets the pressure increase at a rate of say 400 psf/ft without an upper limit. He noted that the maximum value does not apply to piles/caissons. I'm not sure if this was because shoring is generally temporary or if it had more to do with the geometry of piles/caissons. Has anyone dealt with these issues?
Thank you.
Thank you.
