shop doc NX7.5 add machining times 3
berri2
ES
Hi all,
How can I add machining times to my shopdoc?
I have errors customizing it.
Thanks.
Hello.
I have the same problem, Somebody can help us?
Thanks.
Best regards.
The time you see in the Operation Navigator is available in the variable mom_toolpath_time.
Mark Rief
Product Manager
Siemens PLM
Hi Mark,
I have put, this mom variable on my shop doc but it craches,
when I take out.
I have read somewhere, that I have to customize my shopdoc as a postprocessor, but I am not sure. If it´s the point how can I do it?
Thanks in advance.
You might be a little more explicit? I'm also interested in the topic, thank you very much
Es que son la polla ,añade esta variable blabla,¿donde ,cuando,porque?y si no sale vas a la pagina oficial,!joder,.que mi software es como Johnny Depp,no tengo webkey ni gaitas.Este va a ser otro post sin solucion,porque,entre que nx es muy atravesado para estas cosas,y como se explican estos pollos lo llevamos claro,a seguir investigando toca.
Personalmente creo que siemes nx es de los mejores softs ,sobre todo en fabricacion,pero como no tengas profesores que te expliquen los recovecos(como en mr increible),lo llevas claro,intuitivo 0,0%,
y el que no sepa castellano que le den por ahí,estoy hasta los huevos de los idiomas.
Chao,y gracias por nada.(viva la duquesa y el que le quita el polvo)
You need to use the Post to get the mom variables produced by the post.
The variables from the Operation Navigator are available in Shop Docs without postprocessing.
Mark Rief
Product Manager
Siemens PLM
Hi Mark,
Thanks for your reply, you mean that I have to link my shopdoc to a post? or I have to build a shopcdoc like a post?
Sorry but this topic isn't so clear.
Thanks in advice.
Great! Works!
and incredible my formula to convert the time to hours,minutes,seconds.
[expr int($mom_toolpath_time / 60)]h [expr int (((int($mom_toolpath_time / 60)-($mom_toolpath_time / 60))*60)*-1)] m [expr int (((int((int($mom_toolpath_time / 60)-($mom_toolpath_time / 60))*60))-(((int($mom_toolpath_time / 60)-($mom_toolpath_time / 60))*60)))*60)]s
 http://files.engineering.com/getfile.aspx?folder=dcabf753-1841-4cc6-a8a4-d5c834b35ff3&file=DOCUMENTACION_TALLER.pdf
Hi Josemi,
Great Job, incredible...
Great Job Josemi1000.
MUy buen trabajo y estos pollos como bien decias:" Que si esto que si lo otro" Ja,ja,ja.
Enhorabuena compañero.
Un saludo.
0 kiled(OK),the solution is thanks to markrief ,in the 3th post,"the variable is mom_toolpath_time"."
hello everone,
thank mark&josemi10000 information.
In post bulide, i set variable is mom_toolpath_time"
global mom_toolpath_time
set str [format "(##machine_time:[expr int($mom_toolpath_time / 60)]h [expr int (((int($mom_toolpath_time / 60)-($mom_toolpath_time / 60))*60)*-1)]m [expr int (((int((int($mom_toolpath_time / 60)-($mom_toolpath_time / 60))*60))-(((int($mom_toolpath_time / 60)-($mom_toolpath_time / 60))*60)))*60)]s ##)"]
MOM_output_literal $str
export nc file --->(##machine_time:0h 0m 15s ##) Good This is what I want
Hi all,
How can I take out the whole machining time?
I am customizing this variable, with no luck...
MOM_output_literal "<td colspan=1 align=left bordercolor=black><B><font size=2 face=verdana>TIEMPO TOTAL: <b>[format "[expr int($mom_machine_time / 60)]h [expr int (((int($mom_machine_time / 60)-($mom_machine_time / 60))*60)*-1)]m [expr int (((int((int($mom_machine_time / 60)-($mom_machine_time / 60))*60))-(((int($mom_machine_time / 60)-($mom_machine_time / 60))*60)))*60)]s"]</font></td"
Thanks.
