shop doc help
moog2
AU
I'm trying to customise a shop doc (NX6), but i'm not too good with .tcl
I've managed to modify the default "unique tool list by program" to the attatched, which is fine.
Now i want to modify the "advanced web page mill" so that in the 'cutting sequence' it will list the toolpath's in order of programs, as it does in the attatched file.
I think i need to modify the code inside "mill_html_cuttingseq.tpl" but i've tried various things without success, can someone point me in the right direction?
One other thing, it'd be nice if i could get the "unique tool list by program" doc to ignore the "NC program" entry, and just list the programs with toolpaths in them.
I used shop doc, but i changed it for a post, what genererates a html. This post can extract more parameters from the operations, than the shopdoc.
my shopdoc is from the shopdoc_programview_text.tpl.
i used the following code to avoid writing out the main program group:
if {[string match "NC_PROGRAM" $mom_object_name] == 0}\
MOM_output_literal "<TR BGCOLOR=white><TD> $mom_object_name </TD>"
my postprocessor makes the html linked below:
kukelyk
 http://files.engineering.com/getfile.aspx?folder=a90a4c24-b9c3-4b15-aba1-95313a4d1963&file=12345_02_mfg.HTML
thanks i'll try to add that in
