I have an indoor shooting range of 300 meters length, 35.6 meters wide and 5.0 meters high to be conditioned. I have seen many guides which say that the flow inside the range has to be laminar. Moreover they say that in order to achive the laminar flow, the air velocity should not exceed 0.25m/s. I dont have any proof of this velocity. Equation for laminar flow says that velocity is inversly proportional to the cross-sectional area of air-flow channel. When i computed the required velocity based on the dimensions given above, the velocity calculates out to be 5 FPM only (0.025 m/s). So my questions are
1. How can we determine the velocity of air for a laminar flow in a given size of duct. (In this case i have considered the entire range as a duct of W x H of 35.6m x 5m)
2. Is it required to have laminar flow inside the rnage or is it required to have 0.25 m/s of air velocity inside, or both.
3. Or may be it is required to just throw the air from laminar flow air terminals like Price Laminar flow range.??
any guidance much appreciated.
thanks
Walz
thanks
Walz
