Shock Absorber 1
hashanw007
Automotive
LK
Hi all.. have some questions regarding MONO TUBE shock absorbers
1. these dampers have different damping rates in compression and rebound (& at low and high speeds).. But what is the need for these different rates?
2. how these different damping rates (compression and rebound, low and high speed) are achieved in a mono tube damper?
thanks in advance...
2. Check valves.. including some that are biased by acceleration.
Mike Halloran
Pembroke Pines, FL, USA
1) There are different requirements for ride as opposed to handling for shock absorbers. For ride, and impact harshness, it is important to let the wheel rise as rapidly as possible when it hits a bump. Of necessity this means that more damping must be done on the rebound stroke than on the jounce stroke. Even race cars use more damping in rebound, when you consider spring forces perhaps it is obvious why.
Is this for school?
Cheers
Greg Locock
SIG:Please see FAQ731-376 for tips on how to make the best use of Eng-Tips.
some experiment we did on shock performance... needed to know few details of its behavior
