  • Congratulations 3DDave on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Shell forming method with low out of roundness for thin shell
BasakAbhishek
38
My job requires forming a shell of Inconel625 of 2m ID, 6mm thickness, 2m long. The permissible out of roundness is 0.25%. Any idea how this can be achieved? Is there any other method other than a pyramid roller (maybe like forming on a carbon steel "mandrel"?
Abhishek
OP
Contact a custom tube and pipe shop.
If they have the correct facilities.
It can be slip rolled, welded , weld planished
Annealed, then pulled thru a draw die to obtain diameter size. However because it is thin wall and that size. Diameter roundness will be in the constrained condition.
mfgengear
I mentioned the dimensions, 2m ID, 6mm thk, 2m long..its obviously not a pipe and cannot be drawn though a die...
mfgengear
how do you know, then if you know why are you asking.
take your drawing to a shop , and not just one , several until you find the right one.
I said a tube and pipe shop. that can handle that size. it's going to a specialty shop that knows how to make precision tube and pipe of any size.
if a tube and pipe shop can handle 2m dia shells of Inconel 625 and can draw them through a die then it must be the best in business with huge presses and thousands of square metres in floor space...and if I could have taken the drawing to a shop, then is there any need for posting the question on eng-tips, is it?
