espnloser:
An 8-tube pass, fixed tube sheet shell & tube heat exchanger with a 21.25” I.D. will have the following estimated number of tubes:
3/4" tubes on 15/16" Triang. pitch = 258
3/4" tubes on 1" Triang. Pitch = 224
3/4" tubes on 1" Square pitch = 174
1" tubes on 1-1/4" Triang. Pitch = 120
1" tubes on 1-1/4" Square pitch = 94
If you talking about a U-tube, removable bundle, then you can have:
3/4" tubes on 15/16" Triang. pitch = 254
3/4" tubes on 1" Triang. Pitch = 226
3/4" tubes on 1" Square pitch = 194
1" tubes on 1-1/4" Triang. Pitch = 118
1" tubes on 1-1/4" Square pitch = 98
I am citing Ernie Ludwig’s figure’s from his classic book, '"Applied Process Design for Chemical and Petrochemical Plants"; Vol. 3; p.24. If you need 100% accurate figures for fabrication, you should layout out the tube sheet on a drawing board and actually plot your tubes on it, taking into consideration your requirements for tube O.D., partition plates’ thicknesses, tie rods, Outer Tube Limit (OTL), and TEMA’s recommended spacing allowances. In my opinion, the latter method is mandatory if you are fabricating the unit yourself.
The same recommendation applies if you want to find out the maximum number of tube passes in a given shell ID with a given tube OD. Ludwig lists no more than 8 tube passes. I don’t know if that’s the maximum. I certainly have never considered that many and have never done more than 4 or five. I believe anything more than that is impractical and uneconomical – not to mention that it may be self defeating in some cases due to temperature crosses. You don’t furnish sufficient basic data nor do you explain your need or application, so I’m unable to comment further.
I hope this answers your query.
