Is there any requirement per TEMA code on the maximum difference or ratio between the shell side and tube side design pressure? Can the shell side pressure be very high as compared to the tube side pressure? and vice verca? What is the 2/3 rule? I heard of it, but could not find it in TEMA code.
If you think about it, if the shell side pressure is very high as compared to the tube side pressure, the tubes will need to be designed for the high external pressure in the respective load case. If the shell side pressure is too high, will it make tubes too thick?
