Sheetmetal parts, add rounds to rips?
  • Thread starter Thread starter drvogler
  • Start date Start date
D
drvogler
Guest
Guys,
I need to convert an assemblies worth of sheet metal
parts' rips to pretty rounds.
Specifically, I have several parts that have rips in the
corners, and I have my sheetmetal vendor weld those and
grind them to a radius...
All this is great, but now I need to LSN print an
artistic model. If I sent sheetmetal files to the
printers, I get ramparted corners. The printer will not
add anything to geometry we send them. (Pro Weld just
puts a surface patch in there, and isn't translated to
the STL files either.)
So any body know a quick and easy way to blast in
radiused corners into a sheetmetal rips without me having
to go and re-make all the chassis parts?
Any help appreciated,
Dave
Try doing an unbend all, then add aradius (extruded material cutout) into each corner, then bend back all.
The other thing you can try is to save the entire assembly as a step file. Reopen the step file in Pro E. All the parts should now be generic Pro E parts. Add rads to all the areas you require rads, then convert the parts back to sheet metal parts. I have done something similar in the past - worth a go.
I'm not aware of an easy way. Seems like you'll have to convert to a solid and then manually add in the material to represent the solid weld/ground corners.
<tg>
I may be easier to simply hide the edges in the drawing. View; Drawing Display; Edge Display; change edge display to "Erase Line" and select edges.
Thanks for the responses guys.
I exported them to STP as solids and went on an extrusion-
round-fest. Good enough to get a proof of concept.
Thanks again!
Dave
