Sheetmetal drawings: Multiple instances
tydguy
CA
I am new to Pro/E and am trying to create a simple sheetmetal drawing including both the formed and flattened instances of the part. Do you have to create a separate model for each bend state you want to view or is it possible to have all the necessary information in a single part file, then have views reference different instances? Thanks for your help!
Simple,
1) Create the sheet metal part in the formed state. This includes all the bends and cuts.
2) Select SET-UP/SHEETMETAL/FLAT STATE and make a flat pattern. This creates an instance, so just give it a name similar to the formed part. If the formed part is called "PART_123.prt", then call the flat state "PART_123_FLAT.prt", as an example.
3) Create a drawing, and select to include the "PART_123.prt", and add a view. Then select to add the "PART_123_FLAT.prt"model, and add this view as well.
4) The rest is like any other Pro/E drawing.
Hope this helps you out.
Thanks! I am more familiar with Solidworks and was looking for something similar to 'configurations' in SW. I like that all the features and changes to those features remain in one model. I was hoping Pro/E would work the same way. This will work fine for what I need though. Thanks again.
The two parts ARE the same part, what you are doing is making a Generic Model (PART_123.prt) and the flat instance (PART_123_FLAT.prt). They are NOT separate models. The functionality is way above SW (I have used both).
