M
msexton
Guest
Has anyone heard of there being a problem with ILink 2000320 and Pro 2001 build 20001280 in saving sheetmetal parts in a workspace. We are getting a message that the part is not in current session. But if we do a [FILE] [SAVE A COPY] and give the part a new name then it will save it to the workspace. If the part is then put into an assembly and the saves are done by saving the assembly the parts can be modified. But if the sheetmetal parts are modified and saved from the part (even after being saved by SAVE A COPY) then the part not in current session is still the message recieved.
Has anyone else had this problem? Or is it our setup?
