sheet metal standards
You can define this in the sheetmetal standards defined in the sheetmetal parameters option in the sheetmetal design workbench.You can find the info on this in the catia online documentation guide.
i'm talking about sub files. have you seen attached XLS file? i've seen a lot of online documents.there is no explanation on how to define a path for sub files.
found the answer for my question. to define path for sub excel tables Hyperlink must be used in main file.
download.aspx
