I'm trying to add an Edge Flange wider than the Base Flange in Solidworks 2010.
I'm not sure if it's the correct way, but this is what I 've done:
1- I Created a Sheet metal part
2- Then I Added a Base Flange (a 100 X 50 rectangle)
3- Then By clicking the Edge Flange button from toolbar and clicking the edge of the Base Flange, added an Edge Flange. In Edge-Flange Feature manager Clicked "Edit Flange Profile" button and dragged the flange and made it longer than the base flange.
At this step I receive the following Error:
Unable to create the flange from the sketch
If I drag the flange and make it the same length as the Base Flange or shorter, It works fine. But if it's longer, I receive this error.
A screen capture is attached.
Any kind of help is much appreciated.
