Sheet-metal loft bend
Palmgren
NO
Hello
I have a rather simple sheetmetal part I've been trying to model for some while now. The problem is the transition from a square scetch to a circular, and then to be able to continue using other features like edge flange. See attachment...
I've tried loft bend, and converting a regular model to sheet metal.
I'm using Solidworks 2009 for this.
Thankyou for any helpful tips.
Create the flat section, then add a sketch line on the edge of the flat where you want the bends. Add the flange where the sketch is. Add the fillet later.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Why not attach the *.sldprt of whatever you were able to complete?
ctopher, sorry but I don't really get what you're saying.
The closest i can get to the shape i want, is with using the sheetmetal loft bend, the problem is that the edges of this shape is not planar, therefore using features to further build on this is not possible.
I attached a a part that shows the shape i want, the problem is i cannot put a edge flange at the flat end, and the extended circular area is not merged with the other body. (the dims are not important)
 http://files.engineering.com/getfile.aspx?folder=b371158f-e2c0-4870-9498-f726ab6eb3b7&file=example.SLDPRT
I don't think it will be possible to unfold this model in SWx.
With this I think your best bet is to draw out the flat and use sketch bend. It will get you closest to the shape you want. However you still won't be able to put that edge flange on the end.
StrykerTECH Engineering Staff
Milwaukee, WI
Okay, I also have tried many different strategies, nothing seems to work out like i want. Please bump if someone finds a trick to do this one.
Thanks anyway for the effort!
