I have a reinforced masonry building with a rigid diaphragm on the 2nd floor. If the building is a 100' x 50' box do I have to use the entire 100' length as a shearwall?
It seems to me that the rigid analysis would be alot easier if you only used say like 30' of each wall as a shearwall, then the openings, and other torsional eccentric moments would not come into play, since i could keep the center of mass and center of rigidity the same.
Any thoughts?
Any thoughts?
