Shear wall w/openings
Tdog67
Fellers,
i am looking for a good program that would let me design tilt wall panels with openings as shearwalls and load-bearing. Up to 4 stories in height. What are the better programs for this?
thanks
I've used PCA wall and found it good.
Not very intuitive, but it'll get the job done.
Ram Advanse has a Tilt-Up Wall module. I have never used it, but know it is there.
I think the best way is doing by hand or design the wall between openings as a shear wall. I have never seen a good masonry program.
The ram advanse tilt-up module works very well. And it will do up to 4 story tilt-up. The only problem is when you exceed the 0.06 f'c code limit, than ram has some problems, but all in all I think it is very good.
