Shear Wall Design
kennydalglish
8
Dear All
I am a civil engineer and I need to carry out a detailed design of a shear or core wall in a 4 story reinforced concrete building using BS 8110. I would appreciate it if someone would send a spreadsheet and any other relevant information that would be of some assistance.
Dejean
There’s more here than a spreadsheet design. Don’t you have a more experienced engineer to help you with this?
faq731-376
A four storey building is not a major structure with concrete shear walls, but, you have to know what you are doing...
I've attached a lateral load distribution sheet from way back... it'll give you a start at the distribution of forces. I posted this a month or so back, but, couldn't find the thread. Once you know the forces, both lateral, vertical, and flexural... you can set right in and write your own spreadsheet.
Dik
 https://files.engineering.com/getfile.aspx?folder=21f8b0fb-f468-437b-8840-ac0be3187cbd&file=Lateral_Orig.xls
