...just simple question. Let us consider composite (steel and concrete) one span beam.
In case of simply supported beam I design number of shear studs from min(Ac*0.85*fc, Aa*fy). Then divided by length of the beam and by number of studs in one transversal row. Then I can this longitudinal distance lower in region of supports and higher in rest region.
In case of beam with both its ends fixed, in supports there is maximal shear force, but negative moment so concrete is in tension and does not contribute to resistance of the beam.
So how to generaly design number of studs and spacing between them in this case ? Specially in regions where concrete is in tension ?
Thanx in advance
Thanx in advance
