Aakalim103
I am designing a underground tank where the depth of the tank is 9m. I am getting have high shear at the vertical joint of the walls and it seems i would need some kind of shear reinforcement at the wall corner. But i am not sure if these results are realistic since i have never seen shear reinforcement in the walls which led me to think maybe there is something wrong with my model or calculations.
The tank is 9m deep with 400mm thick outer walls. It will be back-filled with soil and we have to consider the water table at the ground surface. The base slab is 600mm thick and resting on rock. I have made a FEM model, considering the wall to be fixed at base and top. (Top slab is 300mm thick). I have not applied any stiffness modifiers since we have to keep cracking at minimum for underground tanks. I know that the shear force will depend on the loading but is it reasonable to give shear reinforcement in such walls?
