I am designing a double shear pin connection that does experience some moment. The connection consists of a 5x5x3/8 tubing fitting outside a 4x4x3/8 tubing with a 1" pin passing through both.
The clearance between these members is approximately 1/4". This leads to some moments that will be generated.
I have checked (ASD) the pin for both allowable shear stresses (0.4*Sy) and allowable moments (0.6*Sy). My question is this:
1.) Is there an AISC unity check that deals with shear and moment in pin connector? Am I adequate with just check the allowable shears and moments independently?
I know these stresses happen at different locations in the cross section, but I cant find any unity check that deals with this. Thanks a lot.
