jung8938
- Jul 11, 2008
- 3
I was hoping to get some advice on correct way to find shear distribution of timber walls along with steel brace frames and finding equivalent size of brace thickness.
Given the base shear, I assumed shear distribution from flexible diaphram and found equivalent thickness for brace frames by setting deflection of timber walls due to bending and shear equal to the deflection of 2D model steel brace (inverted chevron) frames. Then I went back to use the "thickness" to correct the shear distribution and so on..
Is this correct approach? Thank you for any advice in advance.
