Assuming SAE J429 Grade 8 or equivalent material, 59,940 lbf. This computation based on 32 mm full length engagement of the screw.
The pin (screw) has a maximum shear area/unit length engagement of 0.366 in^2/in, 0.539 in^2/in on the box (nut). Expect the screw to strip prior to the nut letting go.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
