I have to disagree. Nowadays, it is almost a requirement to have a good, solid ground plane. This is due to return path currents. The ground leg of the current path will attempt to travel in the lowest impedance path back to it's source. This is accomplished by following the same path that was supplied, via the ground trace / plane of course. This means, that if you do now allow the current to return "under" the same path that it was supplied, you are increasing the impedance of the path. This is where ground bounce comes from.
Since the "purely digital", "purely analog", and "purely RF" IC's are talking to each other, there will be return current losses if you force the current to go through a "small", non-ideal path (seperate ground planes connected at a "point").
If you are concerned about noise on ground, you can do 3 things:
1) You part placement to your advantage. That is to say don't place sensitive components in the immediate vicinity of the "noisy" components.
2) Beef up your ground plane. Make your ground as thick as possible. Perhaps define your board stackup to allow for a thicker inner core for ground. For example, a 4 layer board can be defined to have 1 oz. copper on the inner layers and 0.5 plated to 1 ounce copper on the outer layers. (I believe I have seen this done..)
3) Add extra via when changing layers (esp. when connecting to ground with noisy caps). Adding extra vias will decrease the impedance (especially the L component). This will help minimize the drops associated with the layer transistions.
It is my opinion, that ground should be as thick and as contiguous as possible. Splitting the ground plane often causes MANY more headaches than it solves.
