J
JayP
Guest
I have a "dimple" that needs to be cut out of the surface of my part. It is a SR of about 30000mm and .01mm DP. This gives me a visible circle of about 49mm on the surface. I have revolved a cut and used the hole option. Before I hit the green check mark the model is highlighted to create my geometry correctly, but when I hit the check mark my part goes away and leaves a solid where there needs to be a cut(the cut direction is correct). I have tried the relative and absolute accuracy at .000001. Without the accuracy turned up it will error out altogether. The best I get away with is .05 deep. Our customers do it on the same type of product with the same crazy dimensions and their models are good. What can I do beyond the accuracy that will help?
